LS2 Head Milling Question
Old Jan 12, 2009 | 12:52 PM
Nitro-LS6's Avatar
Default LS2 Head Milling Question
I'm working with a 2006 TBSS with stock bottom end. Is it safe/wise to take .025" off of Livernois Stage 3R Heads?
243 Castings
2.100 Intake Valves
1.575 Exhaust Valves
Using Stock GM MLS Gasket (I believe they are .056")
Will this work with a 233/236 .610/640 Lift Camshaft?
From a calculator I've used, milling .025 will put the heads at 59.83cc. This would make the engine 11.2:1?
Thanks!
Eric
Old Jan 12, 2009 | 01:24 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
You need to be real careful with piston to valve clearance on a intake valve that large. I'd talk with Livernois about the valve drop so you can make sure you'll have proper clearances.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 14, 2009 | 08:46 AM
LivernoisMotorsports's Avatar
Thanks Jason.
Eric, I believe I spoke with someone from IPS that you know (or maybe it was you?) about this. The heads themselves would have no issue from this, but the PTV would obviously be reduced. If you aren't against notching then you wont have an issue, however I could pretty much guarantee you would have to notch with that cam and the heads milled that far...
Thanks,
Andy
