crank sensor from blown up engine
Old Jan 22, 2009 | 03:40 PM
ayousef's Avatar
Default crank sensor from blown up engine
Are the crank sensors supposed to survive in a detonation-resulted scenario where a pistons shoots out the block and damages every other thing in the engine? How rigid are those things (if at all?)
Im thinking my cars problem (fires for a second and dies) might be because of that. I pulled the sensor off my friends damaged LS7 and plugged it into the Warhawk.
What are my chances that getting a new sensor would solve the problem?
Old Jan 23, 2009 | 02:08 PM
Schwanke Engines's Avatar
LS1TECH Sponsor
Is the crank signal good when it is running? Are the RPM's holding steady while scanning it?
Old Jan 23, 2009 | 02:14 PM
ayousef's Avatar
steady? I wish the vehicle fires up and shuts in 0.5seconds.
Old Jan 23, 2009 | 02:23 PM
LS1TECH Sponsor
Could be a VATS problem. Has it been retuned since the rebuild?
Old Jan 23, 2009 | 11:43 PM
5.3LJimmy's Avatar
What reluctor type are you using and what is the crank sensor designed for? There is a different sensor for each reluctor.
