LSX Lower End...Need advice.
Old Jan 28, 2009 | 09:39 PM
gen3performance's Avatar
Default LSX Lower End...Need advice.
Sorry to bother you guys with another main bolt thread but hear me out.
I have my LSX blocked 427 all assembled in my truck but not completely hooked up. Now I have changed my mind on the factory main bolts and want to run ARP studs since I may end up spraying. Taking the engine out is not a problem.
My question is
1. Do I just screw the studs in and go.
2. Possibly loosen rockers, push the pistons down toward the heads, and try to get the crank out to check roundness with studs.
3. Forget about the studs.
I do know i should have had the block line honed with the studs in the first place, but I am trying to get away from bare blocking this thing. Also, the LSX probably has the stoutest lower end of all LS series blocks.
Old Jan 28, 2009 | 10:11 PM
JPH's Avatar
JPH
My question is
1. Yes and No.
2. Whose crank and why?
3. IMO yes! The studs won't make the motor blow up, faulty tune or bad part will!
Old Jan 28, 2009 | 11:36 PM
novaflash2002's Avatar
from what it looks like you have already spent some money in this, so why not go all the way and put the arp studs, or bolts in. its insurance
Old Jan 28, 2009 | 11:43 PM
JRracing's Avatar
I would have put arp's in there to begain with. But I see no reason to beleive the stock studs/bolts will fail either. They were new right?
Old Jan 29, 2009 | 08:28 AM
you would think that, but you see now that you are questioning that idea. i would put arp in for cheap insurance.
Old Jan 29, 2009 | 09:04 AM
Gen414's Avatar
My question is
I am glad the other guys understood you, as I sure dont. Are you asking about MAIN studs? HEAD studs? or BOTH?
If you are talking about HEAD studs, then yes, all you have to do is pop th old bolts out and put the studs in. If you are talking about MAIN studs, it is in your best interest to have teh block line honed.
And YES, I would use ARP studs, and would never ever in a million years think about using factory fasteners when doing a performance build.
Old Jan 29, 2009 | 09:06 AM
Gen414's Avatar
But stock fasteners will
Old Jan 29, 2009 | 09:08 AM
Corey @ Clayton Racing's Avatar
Switching to studs CAN change the roundness of the mains, it might not, but it can. When we line hone motors they are done with the fastners that are going to be used and at the torque setting they will be used at.
 Michael S. Palmer
Old Jan 29, 2009 | 09:33 AM
Robin L's Avatar
LS1Tech Sponsor
I don't know how much you might spray.
If it's less than 300 leave it alone.
If you install the ARP studs I would take it down to bare and line hone with the new studs.
Robin
Old Feb 1, 2009 | 01:53 PM
Sorry for the confusion. Let me elaborate. I am talking about the main bolts only.
Option 1. Screw em in and look the other way.
Option 2. Take the main caps off and try and get the crankshaft out of the engine without taking the heads off. I would attempt this by loosening the rocker arms and pushing the rods and pistons towards the heads. Hopefully I could get the crankshaft out at that point. If it works I would tighten the caps with the studs and check the roundness. If roundness is good, I'm set. If not, then I'm bareblocking it again.
Option 3. Just use the stock bolts that came with the LSX block that are in the engine now.
I am guessing the engine will be 600 to 700 hp NA. With spray I would assume 750 to 850 hp.
Old Feb 1, 2009 | 03:17 PM
KCS's Avatar
KCS
Moderator
I wouldn't use stock main cap bolts on a 850hp build, and I wouldn't just screw them in and go. IMO, it would be easier to take the motor out and align hone it with the studs installed. I wouldn't recommend re-assembling the engine while it's still in the car.
Old Feb 1, 2009 | 06:33 PM
DAVESS02's Avatar
My machinist and most in the know around here are adamant about a line hone with studs. Pulling it down and doing it right will be a lot cheaper then spun bearings.
Old Feb 1, 2009 | 07:37 PM
pmj341's Avatar
I Agree with doing it right, remove the engine and line hone it after you install the studs.
It's all about Peace of MIND!!!!
Old Feb 2, 2009 | 09:04 AM
Gen414's Avatar
Option 1. xxxxxxx
Option 2. Take the motor out, install main studs and line hone the block
Option 3. xxxxxxx
There, I fixed it for ya.....
Option 2 is what I would do
Old Feb 2, 2009 | 01:27 PM
Huh...that makes it alot easier to decide. All right guys thanks for the help!
