MS3 Cam Change Rockers??
Old Jan 31, 2009 | 02:02 PM
jcobra99's Avatar
Default MS3 Cam Change Rockers??
I plan on getting a MS3 cam with prc 2.5ss. Will i need or should i invest in aftermarket Rockers? If so what ratio?
Old Jan 31, 2009 | 02:15 PM
JPH's Avatar
JPH
Stick with stock for now. YT's would be nice though, but I like the Cranes. Problem is, that with the ramp rate of the MS3(comp grind) the Cranes might not work so well.
Old Jan 31, 2009 | 02:33 PM
jcobra99's Avatar
what about harland sharp 1.7s???
Old Jan 31, 2009 | 02:45 PM
JPH's Avatar
JPH
There great. Stock ratio I recommend.
Old Feb 1, 2009 | 11:05 PM
jcobra99's Avatar
Will the hardland sharp rockers work with my stock valve covers?
Old Feb 2, 2009 | 03:52 PM
JPH's Avatar
JPH
Yes they will.
Old Feb 3, 2009 | 10:57 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The problem with the Cranes and HS's is that they're a bit heavy on the tip. We've seen valve float with the MS3 on stock 243 heads with each of these aftermarket rockers, and the problem was alleviated virtually every time by swapping back to a stock rocker. We also HIGHLY recommend the modification that Harland Sharp does to the stock rockers. They replace those pesky needle bearings with a sealed bearing, clean the rockers, etc. That keeps the lighter weight of the rocker, but with more durability in there! These typically run a bit quieter than the stockers as well! HS charges about $300 for this service, and it's worth every penny IMO! We run these in our racecar you see in my sig
My 2nd choice would be YellaTerra ultralites, hands down.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 3, 2009 | 11:11 AM
JPH's Avatar
JPH
Hey Matt, just curious what valve springs did you guys have on the #243s when you did the rocker test?
Old Feb 3, 2009 | 01:31 PM
We've tested with two different beehives and the PRC duals.
__________________
Old Feb 3, 2009 | 01:52 PM
94 guy's Avatar
is there any power to be gained from the HS mod rockers? what about YT's?
Old Feb 3, 2009 | 01:54 PM
JPH's Avatar
JPH
Ok cool. I can see the Cranes acting real funny with the beehives, but the duals should have shown better control, but the dyno showed otherwise I take it.
Old Feb 3, 2009 | 02:51 PM
Duals did control it better....but in some instances, there was still float with the aftermarket rockers whereas the stocker or modified stockers did not have these issues.
__________________
Old Feb 3, 2009 | 03:09 PM
JPH's Avatar
JPH
Were the dual springs that your were using a "Low" or High" frequency spring, and what rpms where you guys expericing issues/float? I do agree that most 90% aftermarket rockers are heavy out over the nose.
Old Feb 3, 2009 | 03:16 PM
aNuBiS's Avatar
So then what is the best option for guys with aftermarket heads that want to avoid valve guide wear, but dont want to suffer valve float either?
Old Feb 3, 2009 | 09:26 PM
JPH's Avatar
JPH
Solid roller is going to need an adjustable valvetrain.
Old Feb 4, 2009 | 08:01 AM
aNuBiS's Avatar
I know this, my engine is solid roller, lol.
I was asking what would someone with a set of AFR or TFS heads use for roller rockers in a hydraulic engine setup that wanted to avoid valve guide wear and didnt want valve float from the heavy tip of aftermarket rocker arms.
Old Feb 4, 2009 | 12:34 PM
Old SStroker's Avatar
Yep, but there are a number of ways to skin that cat, JPH.
Old Feb 4, 2009 | 12:47 PM
JPH's Avatar
JPH
Aslong as you are running the correct valve springs for your application, and your geometry is correct, most aftermaket rockers you look at or choose should not run into any issues of float/harmonics or valve guide wear. I personally don't think people turn these motors hard enough to even worry about being to heavy over the nose.
