Heavy hitters and L92 heads
, so I figured I would start my own thread instead.Why are there no "heavy hitters" running the L92 heads? Cuz of teh thin deck? Lack of options on rocker arms? Intakes? What? I mean, this head (aside from teh thinner deck) has all teh makings of a head that can make boat loads of power. Huge runners. Great flow #'s for stock heads. Large intake valve (especially good for you NA guys). So, I was just wondering what the holdup was, and why you don't really hear of the '92 in competition, or am I just missing you guys that are running them
The reason I am asking is (as alot of you know now) I have a set for my 414" iron 6.0 build and that build is coming to a close very soon, and I will have teh HP #'s to throw at ya, BUT...
I just picked up a LS1 block that I am gonna have sleeved by RED for a big bore/short stroke combo and really want to make some killer NA power, and would be nice to know that I already have teh heads to do it. So, just wanted some thoughts on teh '92 and making serious power. Even you turbo/blown guys running the '92, I want to hear from ya!
Edit: What are some flow #'s on some CNC heads tha tyou guys have seen?
Here are specs on the GM CNC L92's:
Casting Number 12595364 or 12582716
Valve Angle 15-degree
Combustion Chamber 70cc*
Intake Port Volume 279cc*
Exhaust port Volume 99cc*
Minimum Cylinder Bore 4.000”
* Approximate, Numbers are within +/- 2cc’s
Milling Information for Combustion Chamber Sizing:
- Approximately 0.006” per 1-cc
For 68-cc Chamber Remove 0.012”
For 65-cc Chamber Remove 0.030”
Specifications:
Springs: Stock LS1, 12589774
Max Lift: 0.500"
Locks: Stock
Retainers: Stock
Valves: Stock
Flow Chart:
Flowed @ 28” H20 on a 4.155” Bore
Lift 0.100 0.200 0.300 0.400 0.500 0.600 0.700
Intake 69 154 222 266 309 345 358
Exhaust 46 100 136 166 189 202 209
Do you know (or anyone) know if anyone has had problems with teh deck?
With a copper gasket, you can be a little more flexible with the o-ring. The tolerance doesn't have to be as tight.
I prefer a nice TFS,AFR type of head for a strong average power.
Thanks guys
My cam is right under .800 lift, and you can't put a spring on this head to make it work, without alot of work! Machine shop went to work on the head the other day, and were like....Whoops, no room! There are some options, but not easy one's. So, alot of work is necessary is the reason why. Talked with Richard over WCCH teh other day (Great guy by the way) and he said, you are OK until about low to mid .700, any more, and gonna have problems.
So, guys, if I can save anyone the hassle, now you know. BIG cams= no go (for teh most part) on teh L92. So, if you plan on going this route, just be forewarned. But, everyone I talked to (including Richard) said this head is a KILLER head, till a certain point.
