oil pressure???
is this normal to be that low while idling?? before i changed it it was regularly at the 3/4 mark. i switched to mobile 1 10w30. also when i drained it it barely had 4 quarts in it!
i dont see how it could have had better oil pressure w/ less oil in it
That sucks the previous owner ran so low on oil. I'd check your oil level somewhat often to make sure you don't have a leak somewhere.
