Rising or Falling TPS on C6 Vette
Old Feb 1, 2009 | 06:14 PM
C6Antwon's Avatar
Default Rising or Falling TPS on C6 Vette
I recently installed a NOS Digital RPM & Wide Open Throttle switch on my 2005 C6 Vette. I used the purple wire on the throttle body for throttle position. I also used the green wire on the gray connector for the tach signal. My question is, is the throttle position voltage rising or falling (ie. 1-4v or 4-1volts)??
Thanks,
Anthony
Old Feb 1, 2009 | 06:22 PM
davidws6's Avatar
Default Tps
As I remember, TPS starts close to 0 and WOT is 5V
Should be in PCM diagnostic etc....
