07 LS2 with 58 wheel with old cam
Old Feb 12, 2009 | 07:38 PM
minytrker's Avatar
Default 07 LS2 with 58 wheel with old cam
I have a 07 LS2 going in a 99 camaro. Im using the adapter box for the 58-24 signal conversion. I want to put in a cam but can I use a 3 bolt cam setup with the conversion box?
Old Feb 12, 2009 | 11:15 PM
sheesnaz's Avatar
Should not be a problem, but make sure you get the right cam gear so that the computer can pick it up.
Old Feb 13, 2009 | 12:07 AM
Black02SS's Avatar
You will need the cam gear from a 2006 ZO6. Less then $40.
Old Feb 13, 2009 | 10:52 AM
sheesnaz's Avatar
Won't he need the cam gear for a 24X reluctor wheel motor? Like a 06 TBSS, or 05 C6?
Old Feb 13, 2009 | 12:53 PM
jay_lt4's Avatar
if he is using the 58-24 signal conversion box then he needs to keep the 4x cam signal, the box will convert it to the required 1x signal
Old Feb 13, 2009 | 05:49 PM
minytrker's Avatar
I found what I needed, its part# 12586481.
