Unfinished tune , at 1110rwhp still problem solving
whats your spring pressure (seat and open)? I would go into pretty bad float and mine would be very rich too...
Just because you have double springs + damper doesn't mean you're controlling the valves
Looks like the fuel and or spark is not supporting the cylinder pressure.
Might want to try, better fuel or close the gaps up in the plugs and se if you get any change.
You said it blows black at the top of the pull. Too much fuel will also do what you are seeing. Lean it out a bit at the top and see if that makes any change.
Good luck!
Robin
Good luck!
Robin
just have a look at what kurt from ex w2w did with truck coils-3-5 years ago (from memory)
6.80 +200mph something
doubt you are going to make 1500+ hp on the street with that blower anyway-
not putting you down,just telling you the way it is
sometimes the simple things just work-
what happens when you take the aftermarket injector drivers off the factory pcm-does it still do it or they have not done that-
I have seen some of the turbo guys switch away from the reluctor wheel because they were losing signal. It may have been a result of deflection at a given power level.
I asked earlier if it had too much fuel at the top. What is the A/F ratio when it starts to miss?
TR6 ...isn't that a hot plug? In that type of setup I would go to a very cold plug such as a 10. We never run a projected tip in the high horsepower deals. They act like glow plugs sooner or later.
Does the strap shop any heat like it's starting to melt?
Robin
Robin
