Stripped a headstud nut need help asap!
Old Feb 25, 2009 | 02:09 PM
NVR4GET's Avatar
Default Stripped a headstud nut need help asap!
Taking my old head's off the car and I stripped the nut for one of my head studs not the block but the black 13mm nut. I must have had the wrech at a bad angle or something because the rest came off fine. Has any one done this or have any idea how to get the nut off?
Thanks,
Matt
Old Feb 25, 2009 | 03:54 PM
Zturd's Avatar
Just taking a stab at this but if theres anyway to grind at the headbolt depending on which one it is with either a dremel or air tool to flaten down some and pound a 1/2in socket onto it and try that or just try hitting the 1/2 in on. You said its a 13mm so a 1/2in is actually slightly smaller but not by much and hopefully you can get it loose. Worse case you mess up a socket but it the bolt out. Good luck
