[PICS] Halltech's new Katech Track Attack LS7 spec for E85
Old Feb 26, 2009 | 08:34 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Default [PICS] Halltech's new Katech Track Attack LS7 spec for E85
427ci LS7
12:1 compression
Katech forged pistons, 2618 material
Solid bronze connecting rod bushings
DLC coated pins
Piston squirters
Camshaft - Torquer LS7 but on a 116LSA (a little milder)
C5-R timing chain
Head studs/main studs
Katech rod bolts
FAST 65 lb injectors
Later:
Carbon fiber valve covers
Coil relocation kit
Katech belt tensioner
New clutch
Then later this spring:
FAST LSXR manfold
Katech 12:1 pistons
Degreeing the cam with Cam Logic
A good view of the piston squirters
ARP main studs, Katech rod bolts and rebushed connecting rods
FAST 65 lb/hr injectors to handle the increased fuel demands of E85 and the increased horsepower
Old Feb 26, 2009 | 08:43 AM
Big Bird WS6's Avatar
quick question. why use a cam tool to degree it. can your just use the sets on the chain gears?
Old Feb 26, 2009 | 08:58 AM
Haans249's Avatar
Because Katech builds motors properly. Using the timing chain gears is notorious for being very inaccurate, and can be off a few degrees at best.
Old Feb 26, 2009 | 09:21 AM
LS1TECH Sponsor
Well, it doesn't have an adjustable cam sprocket. I wouldn't trust that anyways. Using cam logic is the professional way to do it.
Thanks Haans
Old Feb 26, 2009 | 09:39 AM
hymey's Avatar
Thats a fancy bit of gear, I just use a degree wheel and adjustable timing sprockets.
Old Feb 26, 2009 | 09:57 AM
Stang's Bane's Avatar
I understand how the Cam Logic obtains the readings for the degree portion, but how will it change how the cam is degreed in with no adjustable timing setup??
Sorry for the hijack..
Old Feb 26, 2009 | 10:14 AM
LS1TECH Sponsor
Pull the pin in the cam and adjust the stock sprocket.
Old Feb 26, 2009 | 01:58 PM
Ragtop 99's Avatar
Why did you go a little milder on the cam?
What DCR are you are expecting?
Old Feb 26, 2009 | 02:15 PM
LS1TECH Sponsor
The customer wanted the torquer cam, but he said his wife doesn't like the lopey idle.
10.8:1 DCR
Old Feb 26, 2009 | 04:15 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm guessing you are using LS7 heads.
Old Feb 26, 2009 | 07:22 PM
LS1TECH Sponsor
Yes .
Old Mar 2, 2009 | 11:56 AM
LS1TECH Sponsor
Old Mar 2, 2009 | 03:58 PM
OWN3D BY MY PROF!
You can't post that kind of picture and not post the results.
Old Mar 2, 2009 | 04:34 PM
LS1TECH Sponsor
I will as soon as I have them. We just did break-in today.
Old Mar 2, 2009 | 08:39 PM
armyspeedfreek's Avatar
so sexy
Old Mar 6, 2009 | 01:00 PM
LS1TECH Sponsor
Results: 615hp / 557tq
When we get the FAST 102mm manifold I expect at LEAST 630hp.
