please come in LS7
Old Mar 2, 2009 | 02:51 PM
PONTIAC SLP's Avatar
Default please come in LS7
hi guys i'm wondering and i want to be sure what Cubic inch is the LS7 ? all people says here it a 427ci , but after searching in google i saw`titanium rods length is 6.067 , stroke 4.000 so how much the bore and what Ci the LS7 ?
thanks.
Old Mar 2, 2009 | 03:17 PM
BlueBird346's Avatar
Yea its a 427.
Old Mar 2, 2009 | 03:20 PM
Originally Posted by BlueBird346
Yea its a 427.
how 427 and the rods length is 6.067 , check this link guys
http://www.superchevyperformance.com...p/12586258.htm
Old Mar 2, 2009 | 03:31 PM
Haans249's Avatar
Do a little bit more research and you will find that rod length has NOTHING to do with cubic inch of the motor. Its all calculated with the bore size and stroke, which you will find the volume of each cylinder x 8 = CI. The only thing the rod length has to do with is calculating your compression height of the pistons.
Old Mar 2, 2009 | 03:33 PM
XtraCajunSS's Avatar
Rod length has nothing to do with determining displacment. The bore, stroke and number of cylinders determine displacment. The LS7 has a 4.125" bore with a 4.00" stroke and has 8 cylinders. The rod length only determines the distance the piston is from the crank throw centerline.
Shane
Old Mar 2, 2009 | 03:36 PM
oh i understand now thanks guys
Old Mar 2, 2009 | 08:46 PM
VortechC5's Avatar
It is closest to 428, 427.65 to be exact.
Old Mar 13, 2009 | 02:55 PM
scatillac's Avatar
Default LS7 Actual Displacement
VortechC5 is correct, but if you said it was a 428, that would imply the "dark side of the force" , as that figure was last used by FORD in the sixties!
