LS2 block bore size
Old Mar 5, 2009 | 11:45 AM
serpentnoir's Avatar
Default LS2 block bore size
I have a brand new 6.0L LS2 aluminum block and measured the bores last night.
The numbers ranged between 3.98... to 3.99.... inches. Is this typical of a new block? Is it expected that I do a final hone to 4.0 inches?
I was using a digital caliper which isn't great but I wanted a rough idea of the bore size.
Old Mar 5, 2009 | 11:53 AM
novaflash2002's Avatar
they leave it a little tight, so that you have enuf material to hone in the pistons.
Old Mar 5, 2009 | 11:58 AM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default LS2 bore size
These blocks vary a bit on size. Some of the variation is probably due to the temperature of the block when you measure the bores.
I checked one last year when another member asked the same question. That block measured 4.002". I just checked another new block for you and this one measures 4.0005". The block I just measured is 65 degrees as checked by my heat gun. The one I checked last year was in the summer as I recall.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Mar 5, 2009 | 12:07 PM
you are probably right, I checked it at 45F.
