Yella Terra Rockers
Old Mar 11, 2009 | 04:43 AM
HLF FST's Avatar
Default Yella Terra Rockers
I've decided to install Yella Terra ultralites on my LS2, engine is stock internal, only has headers and ported FAST. Question is this: Is it worth going with the 1.8 ratio over the 1.7's and if so do I need to change valve springs?
Any and all comments would be appreciated.
Old Mar 11, 2009 | 04:57 AM
vettenuts's Avatar
You might pick up a few hp, which with the cost of the rockers, results in a high $/hp ratio. You will need new springs as well so factor that into the cost and you are looking at about $600 for about 5 hp. That is well over $100/hp which is very expensive. Since springs would be needed for a cam, a small cam would be a better option if you don't want anything too radical.
