LQ4/LS2 6.0 Hybird Question
Old Mar 17, 2009 | 11:16 AM
68 SS's Avatar
Default LQ4/LS2 6.0 Hybird Question
I have a '99 LQ4 iron block and I have a stock '05 LS2 rotating assy with the 58T wheel will it work and which crank sensor should I use? I have a set of TSP CNC L92 heads and a G6X3 LGM cam to finish off the long block. It will have a Edelbrock Victor Jr and QFT 750 cfm carb.
I plan on using the MSD 6012 6LS-2 for the ignition and I want to be sure I will be able to get a pulse with the mix of patrs I have. If it all works it should scream in my '68 SS
