408 Built - What push rods?
Old Mar 26, 2009 | 09:14 AM
Warhawk111's Avatar
Default 408 Built - What push rods?
I just got a 408 short block built (LS2) with wiseco dished pistons -6cc im running a custom grind cam 238/241 .617/.638 on a 114 LSA and patriot heads with 12 to 1 compression ratio. I was wondering if i used stock length for the push rods??? im going to check the clearance but i dont wanna go back and forth to the shop to pick up push rods. Anyone got any ideas
Old Mar 26, 2009 | 01:40 PM
sroach20's Avatar
you need to see how much smaller the base circle on the cam is compared to stock. are the heads milled?
Old Mar 26, 2009 | 06:49 PM
DrkPhx's Avatar
The pushrod length depends on your exact setup. Buy an adjustable pushrod checker to measure the exact length needed. It's easy to do and will give you the piece of mind knowing the valve train was setup properly.
Old Mar 26, 2009 | 06:56 PM
SweetS10V8's Avatar
I would get and adjustable and measure, and then try to get thicker wall pushrods for your setup.
I bought the Comp .105" wall pushrods, instead of the .080" that typical of the aftermarket. Comp has .080" and .105"s so you have to make sure to get the right part number.
Old Mar 27, 2009 | 03:12 PM
Warhawk111's Avatar
Thanks
Old Mar 27, 2009 | 03:31 PM
Stang's Bane's Avatar
Go no less than 3/8 pushrods if you can, the bigger diameter is worth more than a thicker wall.
Old Mar 27, 2009 | 06:31 PM
SweetS10V8's Avatar
Is anyone running 3/8" pushrods in stock heads?
