Cam for L92 Heads: Lessons Learned
http://www.youtube.com/watch?v=8ti1zTgln2U
I am trying to get as close as i can to 600 on the motor with my set-up then spray 200 to it.
I am trying to get as close as i can to 600 on the motor with my set-up then spray 200 to it.2000 SS
403" with hand-ported L92s (342/232@.650 on SF 600)
Edelbrock L92 intake with a FAST 1375cfm throttle body (dyno tuning still not done, but obviously going SD)
Mainline nitrous kit 250 shot (plate)
246/254@.050" (306/314 advertised) .621"/.621" 113+4 with Comp Cams short-travel hydraulic rollers
Turbo 400 w/transbrake 4200 stall, ~4800 on the juice
Strange 12 bolt 4.10s, 295/65/15 ET Street Drag Radials
~3600lbs with driver
Looking to turn it 6800-7200 or so as necessary. Might drop in some solid rollers if I have to...
Went 11.0s@119 with 383, ported LS6 heads, LS-R 232/240@.050" .647"/.651" with a 3400 stall on a not-strong-enough 4l60e and Ed Wright tuning.
I'm hoping to get well into the 9's (.70s or .60s) with juice and maybe 10.80s or so on motor.... am I nuts, and what do you guys think of the cam?
LS3 Motor:
stock stroke
pistons with valve reliefs, 4.070 bore
stock ls3 heads, probably mill .040-.050
stock gaskets
ARH 1.75" headers
1. Comp 54-455-11
2. Custom spec
IVO 4
IVC 42
EVO 54
EVC 0
.598/.602
Thanks!!
LS3 Motor:
stock stroke
stock gaskets
ARH 1.75" headers
1. Comp 54-455-11
2. Custom spec
IVO 4
IVC 42
EVO 54
EVC 0
.598/.602
Thanks!!
I don't know exactly what that custom cam is but the best I came up with is 226/234 113 + 4. That is probably a pretty decent daily driver cam right there. Probably carry pretty good power to 6500 rpm but peak around 6100-6300 rpm. 4 degrees of overlap should have nice little lope with good manners.
LS3 Motor:
stock stroke
stock gaskets
ARH 1.75" headers
1. Comp 54-455-11
2. Custom spec
IVO 4
IVC 42
EVO 54
EVC 0
.598/.602
Thanks!!
I copped flak for not putting a big cam in it but don't care and now couldn't be happier with it as it's a very tough daily and the only trouble with it is it fry's the rears when rolling onto 3rd to heavily.
The Hotcam will work fine for a daily check out the the GM performance camshaft comparo thats basically what my cam is except for the XE lobes.
If you want a strip car I would suggest a bigger cam though managed 11.6 in a heavy VE/G8 with a 224 228 xer cam in it, same heads.
cheers
SS Enforcer: Do you have a dyno of your 418 with the previous cam for comparison? Since I chose to stick with the stock stroke, I'm trying to make up for the relative lack of torque by choosing a torquier (is that a word?) cam and not worry about losing 15-20HP above 6000.
cheers
Also milling heads > than ~.030 will cause the intake manifold to seat poorly due to narrowing the V cavity between the heads.
IMO
