What piston for a 4.08 Bore LS3 Stroker
Old May 19, 2009 | 07:27 PM
Rob 's 73's Avatar
Default What piston for a 4.08 Bore LS3 Stroker
My motor had to come out for oil pressure issues. During the tear down there were some groves in two of the cylinders noted. The builder did a .010 cleanup and now I want to make sure they use the right pistons. All the catalogs only list a 4.07 bore. To maintain the proper clearance what piston do I use. The motor will now be a 418. Manley's recommend clearance is .0045 for coated pistons.
Old May 20, 2009 | 04:56 AM
LS1MCSS's Avatar
Will these work?
http://texas-speed.com/shop/item.asp...d=787&catid=38
