l92 Lifter cylinder deactivation question
Old May 21, 2009 | 05:27 PM
schary's Avatar
Default l92 Lifter cylinder deactivation question
Does anyone know how to tell if an l92 engine has the cylinder deactivation lifters without removing the heads??
thanks
Old May 21, 2009 | 07:01 PM
SweetS10V8's Avatar
Yes,
If your valley cover(under intake manifold) is bumpy it has Active Fuel mangament (AFM) If its smooth it does not have AFM.
Old May 21, 2009 | 08:14 PM
schary's Avatar
great.. thank you. .its smooth..
So i can reuse lifters i guess
Old May 22, 2009 | 02:14 AM
rsz288's Avatar
And if you dont have the intake off, the best way to tell is whether there is a connector at the rear of the manifold on top of the valley cover.
It is in the shot above behind the oil pressure sensor.
