Reluctor wheel question.
Old Jun 2, 2009 | 12:30 AM
69dodgecharger's Avatar
Default Reluctor wheel question.
Hi,
I am going to be doing an engine swap for a buddy of mine. I am removing a forged ls2 from his C5Zo6 and swapping it with a stock ls2 out of a C6 Vette.
I am assuming that the reluctor wheels are going to need to be swapped on these engines. Is this somthing a normal machine shop can takle? Or am I going to need to go to a crank shop or somthing else?
Thanks guys!
Old Jun 2, 2009 | 01:21 AM
05gto60's Avatar
it depends on the year. a 2006+ LS2 out of a vette has the new reluctor wheel. if its from an 05, then its the 24x wheel. take a look at LPEs website, they make a conversion box that may be cheaper/easier than swapping reluctors
easy way to tell is to look at the crank position sensor color. if its black, then its 24x, if its gray, then its 58x
http://www.lingenfelter.com/mm5/merc...Category_Code=
Old Jun 2, 2009 | 03:54 PM
Just found out its going into an 05 so I'll be OK, I thought he was getting an 07....oops.
