knocking/ticking noise
Old Jun 11, 2009 | 08:07 PM
bc00z28's Avatar
Default knocking/ticking noise
so a little back story....i have a '00 z28 with a mild tune(done before i got the car) and i always run premium with octane booster...no prob most the time...but this last weekend i changed to 5w-30 oil(royal purple) instead of the usual 10w-30 and now i have this knock/loud tick noise at higher rpm's and on startup...i'm thinking it could possibly be the lighter oil or something to do with a valve or spring...i have no noticeable power loss or anything just that annoying noise...could is be the thinner oil or something more? if anyone has an opinion(a valuable one), please let me know...thanx
Old Jun 11, 2009 | 08:20 PM
rdrage728's Avatar
I would do another oil change back to what you where running and see if it goes away.
Old Jun 11, 2009 | 08:25 PM
GregTSi's Avatar
Probably a lifter tick or something that the other oil was hiding.
Old Jun 11, 2009 | 08:48 PM
allenwesley's Avatar
When you putt the regular oil that you’ve been using back in... bye some marvel mystery oil, it comes in a red container and i would putt half of the 16 oz bottle in your oil... that usually helps with the tick
Old Jun 11, 2009 | 11:36 PM
un17real's Avatar
Cool
IMO experiecne with ls engines they like a thicker oil like 10w40 royal purple i run in the vegas heat 120+ outside with no ticking . a simple oil change and your ticking will be gone. or if u want to save money buy some lucas oil additive and it will thicken you oil up just get the right one
Old Jun 12, 2009 | 03:47 PM
bc00z28's Avatar
Thanks for the info...I'll switch up to 10w40 and see what happens.
Old Jun 14, 2009 | 04:19 PM
bc00z28's Avatar
so yeah....switched to 10w40 and it is less noisy now but it can still be heard faintly..
