**g6x3 cam help**
but its about the same price. If you want a premium duration spring that you dont have to change to often then your going to have to pay. But its features nitriding and Nano peen processing
PRC has a new spring kit as well that you might want to check out. Give them a call and ask them about it. I'll be carrying it shortly, but I do not have them in stock at this time.
Or call TSP and ask about their new premium dual spring.
If you have to swap a cheap spring every 15k miles instead of 25k then your not saving money. (for example) Calling the MFG is the best way to get the facts you need. Some springs fade quicker than others and should be checked at quicker intervals
but the springs will not be tool steel.
good luck
