Recommendations on oil pump
Old Jun 22, 2009 | 07:13 PM
scooter k's Avatar
Default Recommendations on oil pump
I need a good reliable oil pump for a LS2 build. What do you recommend?
I just want something I won't need to worry about.
Old Jun 22, 2009 | 08:40 PM
405HP_Z06's Avatar
Can't beat the stock LS6/LS2 oil pump. Port and shim it for improved flow and higher pressure.
Old Jun 23, 2009 | 06:57 AM
99blancoSS's Avatar
the Meling HV is a popular option
Old Jun 30, 2009 | 04:46 AM
03CobraMike's Avatar
Yep, definitely recommend the Melling high volume. I'm running one right now with the blue spring. Very nice build quality and works flawlessly.
Old Jul 1, 2009 | 02:37 AM
UVETTYA's Avatar
I hope the Meling is a good pump because I just bought one for a new Ls3 motor. Everyone I've talked to says to use that pump because it's a lot better than the stock ones. I hope so.
