LS7 rods with a 4.10 crank?
Old Jul 9, 2009 | 06:57 AM
c5blkvette's Avatar
Default LS7 rods with a 4.10 crank?
Can you use the LS7 Ti rods for a 440ci LS7 based build with a 4.100" crank or would they be the wrong length (6.067")?
Would you need custom pistons or are there ones available off-the-shelf?
Thanks.
Old Jul 12, 2009 | 09:17 AM
Gen414's Avatar
Thanks.
I wouldn't think someone would have "shelf" pistons for that setup, no. You can PM Brian Nutter (member here on LS1) over at Wiseco and get his feedback. Trust me, that man knows his stuff bout Pistons
Old Jul 12, 2009 | 04:22 PM
racer7088's Avatar
Arrow
Thanks.
Crank has to be made to clear piston at that short a rod. The piston would have to have the LS7 pin size or you would have to hone out the LS7 rods on the pin end to .927 which is easy. Also LS7 rods need to be modified to work with a normal crank as they will not work on a normal crank with a normal fillet. Piston just needs to have correct CH as far as that goes and correct pin. There are many that would work and you can just deck the block to get that quench you want or the HG can be changed.
Old Jul 13, 2009 | 12:36 AM
Pwebbz28's Avatar
You would be surprised what might be out there. You can stroke a 350 small block to a 408 and use a 5.8 rod with a piston for a 331 small block ford.
Old Jul 13, 2009 | 05:10 PM
Gen414's Avatar
That is true. You read Car Craft also?
Old Jul 13, 2009 | 11:56 PM
Pwebbz28's Avatar
Hell yeah Engine masters is my favorite. I like the mutt motors. Cool to see what can be thrown together for such a small amount of $$
I would like to see what that 408 SBC would do with some good parts.
Old Jul 14, 2009 | 02:42 PM
ColeGTO's Avatar
Take a look at my web page. I have a 403 SBC with 18° heads that dyno'd at 780HP w/o the vacuum pump. That's N/A also. I would consider mine a "budget" motor also since I built it for less than $10K back in 2005. The car is a little heavy and we don't have the trans brake on it yet, but the car should be capable of mid 9's once sorted out.
Cole
