in a nutshell, 976/l92/l99 AFM with Cam phasing
Old Jul 14, 2009 | 09:22 AM
danf1000's Avatar
Default in a nutshell, 976/l92/l99 AFM with Cam phasing
rather than endless piece-by-piece searching, maybe someone who has done this can harp on in.
cam swaps on these automatic-transmissioned Gen IV engines with the compu gizmos:
here's what I think I know:
--they have lifters that deactivate cylinders. these lifters are heavier.
--they can have a cam swap as long as the phasing is limited to around 20 degrees to avoid interference.
--cam swaps and headers can turn these engines effectively into ls3's as they carry the same heads and are only slightly smaller bore.
--the transmission ends up wigging a bit with cam mods.
here's what I don't know:
--do lifters need to be removed for cam swaps involving high lift profiles? are heavy mass lifters just too much for the increased ramp rates??
--springs and pushrods necessitated for the swap??
--are the new offset rockers capable of handling high lifts without losing over to a non-intended wear area on the nose of the rocker??
--can computer tuning can produce acceptable results
--how can the transmission be acceptably tuned??
Old Jul 14, 2009 | 06:43 PM
SweetS10V8's Avatar
1. YOu have change lifters, 100%. Its not the weight, its that when deactivated anthing over .500 lift wont actually deactivate them. Ive read that they still open.
2. Springs are required, pushrods are an extremely good idea.
3. Stock rockers will take whatever you throw at them for the most part.
4. YES, you can tune them. Comp made a 70hp (430hp to 500hp) gain and didnt loose any torque anywhere on a almost stock L92 (had headers) with only a cam and springs swap.
5. The trans is just like any other. line pressures, shift points, etc, etc...
Old Jul 15, 2009 | 10:03 PM
bigwillys58's Avatar
Originally Posted by SweetS10V8
1. YOu have to change the lifters, 100%. Its not the weight, its that when deactivated anthing over .500 lift wont actually deactivate them. Ive read that they still open.
basically what this guy said. the trans (mine is the 6L80E and had no troubles) does not wig out with cam swaps though, just requires a little finessing. livernois motorsports has AFM delete cam packages for these motors. thats the route i went and couldnt be happier. FYI the g8 uses the L76 engine
Old Jul 16, 2009 | 05:42 AM
Bring the Noise's Avatar
There are a couple of performance cam's out for the AFM (DOD) engines with the LS3 heads.
New Era has both a Low lift and a high lift cam package under the G8 section on there web site.
You can tune the trans for most of the issues but a higher stall torque converter is usually required with larger cams shafts on automatics.
