L92 roller rockers
Old Jul 19, 2009 | 12:10 AM
scooter k's Avatar
Default L92 roller rockers
What's the best brand of roller rockers for a L92 head? Do you go with 1.7 or 1.8 ratio?
Old Jul 19, 2009 | 12:33 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
at this moment there are only a few. they range in price. when crane was still up and running, they made a 1.7/1.8 rocker for them. then there is jesel and t&d....also yella terra. you can guess which ones were the cheaper 2 out of 4....dont remember on the comp rockers though, or harland sharp. if they are not out yet, they should be soon
for the price and avail, i would say yella terra....
Old Jul 19, 2009 | 12:43 AM
smok'nZ's Avatar
MASS seller approved
crane is what i have summit has them for 700$ with pushrods 1.7
Old Jul 19, 2009 | 12:46 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
unless they bought ALOT of stock from them, they are prob not avail anymore, since they have not started back up yet, and have been out of business since Feb....
Old Jul 19, 2009 | 02:02 AM
njc.corp's Avatar
Cool
Think crower got a set out also-
Some of these rockers for the l92 heads have not been promoted well.....
Old Jul 19, 2009 | 05:15 AM
WKMCD's Avatar
I've been running YT Ultralights for a while and they've been great.
Old Jul 19, 2009 | 10:02 AM
scooter k's Avatar
Can you use the stock rocker covers with these?
Old Jul 19, 2009 | 10:55 AM
scooter k's Avatar
What about getting the Harland Sharp modded stock rockers?
Old Jul 19, 2009 | 11:04 AM
SweetS10V8's Avatar
Thats what Im thinking of doing. The stock rockers are hard to beat, no big bulky roller wheel that really doesnt do anything but add weight.
Comp just started doing the trunion upgrade too as well as HS.
Old Jul 19, 2009 | 11:31 AM
fossil's Avatar
I have been using the stock rockers that have the Harland Sharp trunion's for a couple years.
Old Jul 19, 2009 | 06:06 PM
3fingas's Avatar
Roger Vinci at crane has one more set for 599. if its not gone already. 1.8 RAR
Old Jul 19, 2009 | 06:17 PM
burgers's Avatar
I ran 9.44 @ 143mph with stock L92 rockers and LS7 lifters spinning to 7200 rpm last night. I have had no problems so far. I would say upgrade the trunion's for peace of mind.
Old Jul 20, 2009 | 09:26 AM
8ByGoat's Avatar
I have run the yella terras for about 20k miles with no complaints or issues.
Old Jul 20, 2009 | 10:08 AM
tektrans's Avatar
stock rockers here.
Old Jul 20, 2009 | 10:13 AM
TT632's Avatar
Originally Posted by tektrans
stock rockers here.
What kind of RPM?
Looks like more than a few 9 second cars running stock rockers. Any failures out there?
Old Jul 20, 2009 | 10:33 AM
tektrans's Avatar
Hasn't seen more than 7k even. Limiters set on 7100 and I've logged her as high as 70xx on the 1-2 shift. Motor doesn't really like anything more than 6600.
Old Jul 20, 2009 | 04:29 PM
Zman420's Avatar
Just keep in mind that if youre going to change to roller rockers over factory rockers, that if youre going to ever run a big cam then stay with 1.7 ratio.. The fast ramp rates that big cams make dont work well with 1.8's.
The only "upgrade" for going 1.8 over 1.7 is about .027" of lift. Sooo if you wanted to try to be slick, you could go 1.8 with a ls6 cam (.550 lift) and have .580 lift without a lope.. My car did 381/404 with that same setup and bolt ons and sounds stock as **** and purrs like a kitten.. lol its all in what you want tho. IMO if youre going to run a bigger cam, then just save youre money and stay with the stock rockers, theyre proven to hold up to the abuse..
Old Jul 21, 2009 | 12:16 PM
ShoddyHog's Avatar
I've been running Yella Terra 1.7s for the last 30k. Just changed my springs, and everything looked good except for one small contact area on my valve cover. One whack with a hammer, and that problem was solved. Hell, it was so quiet even with that, I ran for over 30k without knowing it.
Gerry
