knocking after cam install..
Old Jul 30, 2009 | 08:46 PM
400rwhphemi's Avatar
Default knocking after cam install..
camshaft-238/242 .581 .581 113lsa comp cam
livernois 7.400 pushrods
livernois valve seals
patriot gold dual valve springs/retainers
i just installed the camshaft today everything went smooth camshaft is dead on i marked the chain in 2 spots, i have done over 100 hemi swaps so i was sure to get the timing dead on..
either way its a loud knock and i can hear it on what i think both sides like a lifter..
5 monthes ago i was driving the car and it just started doing this same sound out of the blue.. then it went away after about 5 minutes of driving..
also when i pull the fuse for the fuel pump and crank it over with no fuel and just the starter it makes no noise..
any ideas?
i have a vid coming
Old Jul 30, 2009 | 08:48 PM
Originally Posted by 400rwhphemi
Car-2005 gto
patriot gold dual valve springs/retainers i didnt use any shims
any ideas?
i have a vid coming
also forgot to add that i took the drivers side valve cover off and had someone watch the lifters.. they are all moving..
Old Jul 30, 2009 | 09:19 PM
slowrollin93's Avatar
I see the problem in your sig, you have a flowmaster.... jk could be a rocker arm not torqued all the way or could be a bad lifter i guess. Did you replace them?
Old Jul 30, 2009 | 09:37 PM
no i didnt... they where fine for the last 8k miles..
Old Jul 30, 2009 | 10:44 PM
05JUDGE's Avatar
I assume you installed new seals with the Springs also? Are you using the stock rocker arms?
Old Jul 30, 2009 | 10:54 PM
3fingas's Avatar
did you check the pass side? Dont know if I missed that. Just to make sure a spring didnt pop. Also why not some HP behives with that cam. Maybe spin the crank by hand could help determine where its at. Hope you find it.
Old Jul 31, 2009 | 05:51 AM
69LT1Bird's Avatar
You said it stopped when you disabled the fuel pump, you may have an injector knocking. Unplug one injector at a time to see if it goes away.
Old Jul 31, 2009 | 07:55 AM
thanks for the tips guys.. i never unplugged the injectors..
i did install brand new seals from livernois they were just a press on type seal went on pretty hard..
also im thinking now that maybe the pushrods are to long..
cam is ground on the xer lobes..
yes stock rocker arms also..
Old Jul 31, 2009 | 04:02 PM
69LT1Bird's Avatar
It doesn't matter if they got unplugged or not, the noise is a hammering type sound from an injector that has a problem, just something easy to check.
Old Aug 1, 2009 | 12:14 AM
1BADAIR's Avatar
how much preload?
7.425's may be needed
Old Aug 2, 2009 | 11:54 AM
ahartz28's Avatar
Originally Posted by 1BADAIR
how much preload?
yea sounds like rocker noise
Old Feb 10, 2010 | 12:26 PM
Cruz Lo's Avatar
I know this doesnt help you. But your not alone!
Just put a TS cam and dual springs in my camaro.
I had a BAD noise 30 seconds after I started it. Like a squeeky knock. I took the valve covers off. Found nothing wrong. No issue turning over by hand. Put it back together, started it. Noise came right back.
While I was listening to the engine it seemed to come from center of the block (Lifter?) well after about 30 sec it went away?
let it idle to full hot twice and its just as quiet as can be...
Old Feb 11, 2010 | 09:37 AM
InsaneDomestics's Avatar
There can be Numerous Varibles when someone says "Knock." Post up a Vid and that will help
Old Feb 11, 2010 | 10:54 AM
Pwebbz28's Avatar
Slow knock will be lower end and a fast knock will be top end. Im willing to bet you have a lifter not pumping up. What are the specs on your heads? Are they milled? Did you check your PTV?
Old Feb 12, 2010 | 02:19 AM
Yeah I'm aware of that, just sayin a Vid Clip might help a little better than him tryin to describe it.
