Is the LS3 padding/cover necessary?
Old Aug 3, 2009 | 08:16 AM
OutKlast's Avatar
Default Is the LS3 padding/cover necessary?
I swapped LS3 heads and LS3 intake into my C5 corvette. Found out the LS3 intake is just to tall with the padding/cover on it. It fits just fine without it though.
I have maybe the thickness of a pencil in clearance with the padding/cover gone. It's so tight it wouldn't even fit with just the plastic cover and no padding.
What does that padding do? Is it just to quiet the engine down?
Old Aug 3, 2009 | 08:53 AM
sroach20's Avatar
just for looks, i didnt use it either.
Old Aug 3, 2009 | 09:43 AM
hookemdevils22's Avatar
i think it's for sound deadening. mine interfered with the holley tb. i pulled it, it looks just as nice, if not nicer, plus i shed a pound or two.
what'd you do to connect the ls3 map sensor? doesn't it have a different pinout than the earlier ones?
Old Aug 3, 2009 | 09:54 AM
ajw2500hd's Avatar
Same here shes hanging on garage wall!!!
sroach20's Avatar
i ordered a pigtail for the ls3 map sensor and spliced it in.
Old Aug 3, 2009 | 10:18 AM
OutKlast's Avatar
Just got back from the GM dealer, I'm doing the same. Picked up a pigtail with the new connector to splice in.
I could always just cut off the rear portion of the pad/cover and that would work too.
