compression ratio
Old Aug 6, 2009 | 02:54 PM
Daryn's Avatar
Formerly darynC-10/23/10
Default compression ratio
stock l92 is 10.5.1 ....
heads are milled .040... what would it be now?
Old Aug 6, 2009 | 03:18 PM
hookemdevils22's Avatar
your best bet would be to cc the heads, but i believe the general rule of thumb is 1cc per .005" removed (don't quote me). in that case, you're about 62-63 cc, or 11.25-11.4:1 CR. i'm not sure the other specs (piston deck height mainly), so it's a little tough to determine the exact CR.
