anyone use elliotts cams before?
230/226 .600/.600 113 LSA - choppy idle, works well with 3200-3600 stall and
3.73/4.11 gears. 2100-6800 RPM.
Just looking at those specs it appears as though he took your combo into consideration. That is probably not the cam he would've spec'd for a 3400-3600 lb F-body. That cam is less about peak power and more about low to mid range to get that tank off the line and that LSA lends itself well to the runner design of the intake. Although, when you say choppy idle, I'm not sure if you care or not...but I wouldn't think that would be too choppy. It'll def sound cammed, but none of the wild lope people seem to get a hard on for these days.
