TBSS Throttle body options
Old Aug 15, 2009 | 08:06 AM
bad94sup's Avatar
Default TBSS Throttle body options
I recently picked up a TBSS LS2 engine (06) that I will be using in my Chevy II swap. I do not want to run the E40 ECM setup so I will be converting over to a cable throttle body. What are my options for a throttle body on the stock intake? Is it worth upgrading the intake as well?
Thanks,
Andrew
Old Aug 18, 2009 | 12:45 PM
NemeSS's Avatar
www.morrismotorsports.net, sponsor here
has 90 and 92mm tbs that will work for your intake. direct bolt on, cable driven and less than 300$
Old Aug 19, 2009 | 08:58 AM
bad94sup's Avatar
Cool, so basically any 90mm or 92mm cable driven should work, right?
Thanks,
Andrew
Old Aug 19, 2009 | 10:36 AM
NemeSS's Avatar
Thanks,
Andrew
yup. all the oe 90mm tb are dbw. need to go with aftermarket for cable drive 90mm.
Old Aug 20, 2009 | 07:06 AM
bad94sup's Avatar
Thanks! I'll likely be able to find something in the classifieds here.
