lets talk about LS7 HEADS ....
Old Sep 19, 2009 | 11:40 PM
MelScrilla's Avatar
can LS7 heads work on smaller strokers like 408 or a 418? If so I wonder why more people don't go this route instead on L92.
The LS7 heads come in at a price right under heads like trickflow 245's.
Old Sep 20, 2009 | 05:24 AM
davidws6's Avatar
Default Bore size
I remember reading a post where the smallest size was listed for the LS7 heads. I think it was 4.080 or 4.1
Old Sep 20, 2009 | 09:27 AM
Old SStroker's Avatar
Originally Posted by DBN
Jesel (adjustable) rockers are only required when running a solid roller camshaft. I am running stock LS7 rockers with my ETP LS7 heads.
Not necessarily, but it takes some work to run the stockers with a SR. I think that it is worth the effort.
Old Sep 20, 2009 | 10:46 AM
COPO9560's Avatar
Thought LS7 heads required minimum of 4.125 bore???
Old Sep 20, 2009 | 11:18 AM
davidws6's Avatar
Default GM says 4.1 min ?
https://ls1tech.com/forums/generatio...-080-bore.html
Old Sep 20, 2009 | 11:33 AM
3timeracin's Avatar
Its not worth it, if you look at many head flow charts most heads lose at the least 10+cfm by going from a 4.125 bore to a 4.030 bore and thats heads made for small bores. The ls7 has a 2.20 int valve that would be so shrouded by the cylinder you would be back to ported Ls6 flow numbers. This would also cause alot of turbulence in the runner behind the valve and create alot of problems with port velocity.
Old Sep 20, 2009 | 08:12 PM
formula17's Avatar
From what I've found and heard, The intake isn't the problem its the exhaust valve that'll scrape on anything less then 4.100" bore.
Old Sep 20, 2009 | 11:31 PM
LSmonster's Avatar
Originally Posted by 4evervette
i have been searching here and there ..looking for options
so far :
West Coast Cylinder Heads ..
Precision Race Componets CNC Ported LS7 Heads:
ETP heads ....
any one hae used any of the above or any other option plz chime in with ur experience ....
what typicall cost ??
do u need to change rocker arms or not type of valves ?!
what are the avreage HP gains ..?
thanks
I've used them all, except the Precision Race Components.
E/T and WCCH ported ALL PRO heads are fantastic!... I've used a lot of them without any issues. Both are pricy, but you get what you pay for...
Old Nov 16, 2009 | 10:27 PM
TKAYRC3's Avatar
ETP made a 4" bore LS7 cylinder head to run on smaller bore engine, worked great in my 408 w/hyd roller and stock LS7 intake ran 10.0's @135 in a 3400 pound F-body.
Old Nov 18, 2009 | 06:00 PM
john_sblendorio's Avatar
ET LS7 with Jesel's here
Old Nov 18, 2009 | 09:26 PM
Busted Knuckles's Avatar
John, do I read your sig right - 1002 rwhp and 928rwtq???
Gotta live in Texas to have cojones big enough to climb behind the wheel of that monster. You may be my new hero!!!
Old Nov 19, 2009 | 12:48 AM
  #32
CamaroSS22's Avatar
I have a fully built LS7 from TSP, even drove it out there to have it dynoed. Made 550+ through a 12bolt and stock LS7 intake and got close to 30mpg on the interstate. Cant beat that.
Old Nov 20, 2009 | 10:08 AM
  #33
flatchat's Avatar
Mast motorsport LS7 heads. You can use factory ls7 valve train. Talking to BAZ at lsx country.com and he will be listing some deals soon.
Old Nov 20, 2009 | 10:49 AM
  #34
ringram's Avatar
Mast ones are the new ETP heads IIRC.
Cary is working with them.
Old Nov 21, 2009 | 06:27 AM
  #35
rsz288's Avatar
The LS7 exhaust valve misses an LS3 cylinder wall (4.065" bore) by about 0.030 at full lift (LS3 exhaust clearance is about 0.070"). Intake is about 1/8" away.
Be interesting to know how the exhaust flow is affected.
Old Nov 26, 2009 | 11:12 PM
  #36
Yup, no gimicks 1,002/928 corrected with 93 octane through the air filter. It will suck your eyes into the back of your head.
Old Nov 26, 2009 | 11:14 PM
  #37
How about some flow details? Are these worth upgrading from my ET LS7's?
