Patriot Heads quality?
Old Sep 7, 2009 | 07:17 AM
Bader-X's Avatar
Patriot Performance is still a sponsor on this site their ad is on the right.
Old Sep 7, 2009 | 07:52 AM
rpmauto's Avatar
I learned, budget heads yeild budget results. My ported ls6 heads are nice, but i have a set of afrs coming now.
Old Sep 7, 2009 | 08:39 AM
Ls2 cruiser's Avatar
I am thinking of spending a bit now. I might go the TFS 225cc CNC heads. I am going to see a blower expert in Aus first to see if I should go the 235cc TFS heads. I am also going to get a blower cam 214/224@50 .580/.590 lift, bar lifters, roller rockers from one of your sponsors. The TFS heads are a bit cheaper than the AFR heads. Cheers Russ
Old Sep 7, 2009 | 12:58 PM
smok'nZ's Avatar
MASS seller approved
the reason i mentioned #317's was bc he has a pic of a supercharger in his avatar so i assume he is FI but if you are N/A i wouldnt buy patriots new for 1200 if used for 500-700 yes i paid 575 shipped for a set of stage III's one time they are a nice piece but not the best by far
Old Sep 7, 2009 | 03:34 PM
LSWNDR's Avatar
I know the older style heads were notorious for broken valve guides and truth be known thats what happened to mine. You either get a good set or a bad set. The newer castings are suppose to be alot better. In all honesty called texas speed and holler at john j. Best prices, quality work, and great results.
Old Sep 7, 2009 | 06:56 PM
The avatar is correct, I have a 8 psi Harrop blower on the ls2. I gather the 317 is the intake runner size. What brand is it? Cheers Russ
Old Sep 11, 2009 | 01:53 PM
smok'nZ's Avatar
they are stock casting head #317 70 or 72cc runner size is 225 i belive
Old Sep 12, 2009 | 09:17 AM
ChucksZ06's Avatar
I have them on a 403 I built. I have not had it dynoed but it is a lot faster than c6 z's in 4th gear pulls so I am quite sure I am at the 500 + rwhp level.
Old Sep 13, 2009 | 08:43 AM
davidws6's Avatar
Default 317's
I have a set of 317's on my 402. With a FAST 90/90, it popped 482 RWHP and the tuner didn't know WTF he was doing ! Now it's in a SD tune and it pulls great! 317's would be a very cost effective solution, but granted the TFS or AFR's would probably out do the 317's
I think I have less then $1K in my 317's They were new castings I got off ebay for like $199 3 yrs ago. They were ported locally. With a CNC port job from like WCCH or whoever, they might flow better.
I grabbed a set of LS7 heads from Richard @ WCCH. In talking with him, he seems to know his stuff!
Old Sep 13, 2009 | 08:55 AM
SweetS10V8's Avatar
Originally Posted by smok'nZ
they are stock casting head #317 runner size is 225 i belive
IM pretty sure its 210cc on the intake runners. 225cc is an aftermarket size.
Edit: Anyone else notice when i quoted him his "number/pound" symbol became a "does not equal" sign??
Old Sep 13, 2009 | 09:03 AM
zeake's Avatar
I would personally only buy heads from a particular sponsor. http://www.proheads.com/
If I am not mistaken they do the heads for Nelson Racing Engines.
Old Sep 14, 2009 | 10:15 PM
  #32
Eric Fischer's Avatar
I am running Patriot heads on both the cars in my sig. The '98 has 500+ passes on them and the '01 has 250+ with nary an issue. In fact the one time we went all out with the '01 it went 10.79 @ 124. Not bad for a budget head. I would definitely buy them again.
Old Sep 17, 2009 | 07:54 PM
  #33
325trooper's Avatar
Originally Posted by RyanSws6
I had them on my 408 got 455/455 and peak 5800. I tore it appart 2 days later.
You pulled the heads because of a peak dyno number you didn't like? Should have took it to the track. I helped install a set of used Patriot stage 2's (he bought for $750), G5X3 cam on a full weight Z28. The owner ran a 11.3 with an M6 and mail order tune. I believe he got it into the 11.1's.
