dream ls7 to run a ford 460
Please provide some basics such as:
-BUDGET! very important - do you realize a LS7 long block will run you near
$10k?
-HP goals? This is a big, big factor. You might be able to get there with a built LS1, a LS2 or you may need the LS7. You'd be surprised what you can build out of a LS2 block with some nice heads.
-Do you plan any supporting mods to the T56? Clutch, internals, etc..? Your replacing your rear-end - not a cheap move. Again, budget, goals? Do you want a 10 sec F-body? Full interior? What is your expected "race" weight?
The only info we have on this ford is this:
-Will you drive this on the street, just race it, 90% street, 10% strip? Makes a big difference in cams, intake, etc... With your stealth desires - your talking a low profile stock type intake - maybe a Fast if you ground off their logos.
Bottom line - give us more info and you'll get a much better, detailed answer with fingers pointing you in the right direction.
