To sleeve or not to sleeve....
Old Sep 14, 2009 | 09:18 AM
briannutter's Avatar
Originally Posted by T-Bones Goat
I was just wondering what they would do if they clearanced the sleeves wrong and the piston skirts were out too far?
? Their sleeve length is longer than most blocks. Long enough for 4.125+ strokes with their superdeck 1 and a 4.500 stroke with their superdeck 2. I do a lot of pistons with these guys and everything was laid out from the start.
Old Oct 13, 2009 | 11:38 PM
sixpack_2_go's Avatar
Originally Posted by davidws6
Steve @ RED is the man. He dry sleeved my LS2 block and NO problems what so ever. The machine shop who finished up the block said that RED's machine work was top notch! I'm sure there's other places who do it but I believe Steve worked with Darton on the sleeve development.
I stopped in @ Steve's n checked him out before I sent my block out. His shop was cool...
is "RED" a machine shop? is their a website? how do find it?
Old Oct 13, 2009 | 11:44 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
http://www.raceenginedevelopment.com
Old Oct 15, 2009 | 09:20 AM
ERL Performance's Avatar
If you guys are going to be down here at the LSX Shootout come by and check out our booth. We'll have our ERL Dry Sleeve, Superdeck I 6 bolt and our Superdeck II on display.
Old Oct 15, 2009 | 09:29 AM
ls 2 goat's Avatar
Ya maybe you should take the one you did for me.....The machining was awesome
Old Oct 15, 2009 | 03:42 PM
jmdgto's Avatar
what happened ? i love to hear about sponsors that do bad work.
Old Oct 15, 2009 | 03:45 PM
NemeSS's Avatar
i would like to run with a ERL n/a engine one day
Old Oct 15, 2009 | 04:39 PM
ls 2 goat's Avatar
Ya I woulda loved to have run it in my FI setup but the only thing it was good for was keeping papers from blowing away.
Old Oct 15, 2009 | 06:37 PM
G Engines's Avatar
It was a nice paper weight at $3200
Old Oct 15, 2009 | 06:39 PM
T-Bones Goat's Avatar
Old Oct 15, 2009 | 06:47 PM
flatchat's Avatar
OK so what was the issue?
Old Oct 16, 2009 | 07:17 AM
  #32
99blancoSS's Avatar
good info/quote on sleeves in another thread I'm posting in here :
Originally Posted by Steve - Race Eng
Like I said, I have Darton Seal Tight dry sleeve blocks out there holding a thousand to the wheels. Build and tune the engine right, make sure you have sufficient cooling capacity and you will be fine on pump gas to that power level. Above that I recommend the MID wet sleeve.
Stock LS7 blocks hold up fine with race gas. You must keep the stock block out of detonation or you will split a wall.
It is a lot easier for me and cheaper for you to sleeve the block before it cracks if you intend to run pump gas with high compression, boost or nitrous.
I sleeve many brands of engine blocks, not just GM LS blocks. The Toyota 2 liter 2ZZ engine used in the Lotus is holding 750 to the wheels with the Darton Seal Tight dry liner. That's 2 liters, not 7.
My MID wet sleeved block 3.2 liter Acura FX Motorsports NSX Time Attack car (Cricket Wireless Sponsored) makes 900 flywheel horsepower from 3.2 liters. They won the last four races and set new track records at each of those races.
Note that these two examples have four bolts around each cylinder. In fact, all the block makes I wet sleeve with Darton MID sleeves have only four bolts around each cylinder. It's all in the building and tuning!
To answer the question on the difference between wet and dry liners. Dry liner does not come in contact with coolant. It fits in the aluminum bore of the block and depends on that aluminum bore to keep it round. A wet liner does away with the aluminum wall and is in direct contact with the coolant. Wet liners have a much thicker cylinder wall than a dry liner and do not depend on the block for support to keep them round regarding piston side thrust or cylinder pressure. Examples, the Darton wet liners used in diesel tractor pull hold over 125 lbs of boost. Nissan 3.5 liter MID sleeved V6 2,200 hp on methanol with 60+ lbs. of boost. Honda 2 liter MID sleeved four banger 1,450 hp on methanol with 45 lbs. of boost. Ford 5.4 liter MID sleeved GT40 2,200 hp (not sure on the boost on these).
Steve
Old Oct 17, 2009 | 09:43 AM
  #33
ls 2 goat's Avatar
I'm not doubting the abilities of a sleeved motor. I'd love to be running one myself but the shop that did mine decided it be fun to go at it with a chainsaw....
JUST FOR CLARIFICATION THAT LAST PICTURE IS SHADED TO SHOW HOW MUCH THE PISTON WAS HANGING OUT OF THE CYLINDER
[/QUOTE]
Old Oct 17, 2009 | 10:01 AM
  #34
themack56's Avatar
Exclamation
ls2 goat, you sure that is not for clearancing? i have a resleeved ls1 black that is notched similar to that for clearance of some sort?
Old Oct 17, 2009 | 10:11 AM
  #35
ls 2 goat's Avatar
Yes that is for clearance. Problem is the block was already clearanced. They decided to clearance it again after being told not too. Take a look at how far the pistons hang out. Also the shop tried to charge me 1200 for said hack job clearancing.
Old Oct 17, 2009 | 10:12 AM
  #36
will01's Avatar
signing up; i have heard nothing but good things about erl - are you working with them to fix the problem?
Old Oct 17, 2009 | 10:21 AM
  #37
ls 2 goat's Avatar
Thats a thread all in itself. Still working on that one. Yes, they refunded my money and sent me a core but this was only after weeks of long phone conversations and finally threats of legal action (they had the block 2.5 months). It was good times to say the least. Sad thing is, I had heard nothing but good things about them. Then they tried to pull this ****.
Old Oct 17, 2009 | 10:39 AM
  #38
will01's Avatar
That sucks.... Katech and RED are excellent if you are still looking for some engine work. Many friends have gone to both and had nothing but good things to say - and their cars are still running strong.
Old Oct 17, 2009 | 11:46 AM
  #39
racer7088's Avatar
Arrow
You're not saying ERL clearanced the block like that? It looks like a second shop re-clearanced it? Nothing I have gotten from them is like that! If the shop receiving the block from ERL did this it can't be ERL's fault?
Old Oct 17, 2009 | 12:13 PM
  #40
ls 2 goat's Avatar
YES! ERL clearanced my block like that. My shop did nothing to the block but hone it and throw the pistons in to check clearances (it came from them rough bored). ERL sent the block to us like this and then gave us the big F you when it was brought to their attention. If you'd like I can send you the emails they sent me on it.
