max RPM with 4.100 crank
Old Sep 24, 2009 | 09:17 AM
abbaskhan's Avatar
Default max RPM with 4.100 crank
whats the safe max rpm a FI application a 4.100 crank can handle
Old Sep 24, 2009 | 11:30 AM
427's Avatar
427
Depends a little on power level and the quality of the crank itself. If it is a 4340 center counterweighted crank with properly matched components it should be fine at 8000, if the right parts are used and the supporting oiling is in place 9000 would be achievable.
Kurt
Old Sep 24, 2009 | 02:08 PM
98Z28CobraKiller's Avatar
Restricted User
What motor do you intend on putting that in? What length rods? NA?
Old Sep 24, 2009 | 03:11 PM
NemeSS's Avatar
7500rpm with 4.1 stroke will be around 5125 fps piston speed
with quality bearings,assembly and premium parts it should have no problem spinning that.
NemeSS's Avatar
Kurt
yes, what he said
Old Sep 24, 2009 | 05:24 PM
abbaskhan's Avatar
its a FI application vortech ls2 block
can i do a 6.125 with a 4.1 stroke in a ls2 block
what im trying to do is keep the stock bore and add some stroke in order to add tq but also rev her to atleast 7500
