What is the best block for 454
Old Oct 28, 2009 | 07:40 PM
red 454's Avatar
Originally Posted by ringram
Try LS7 or similar I think was the intention mate. ls3=ls9=lsa=l92 head.. well portwise anyway.
is there a link to ls7 block/head speck similar to this ls3 one
this is very informative for stock stuff and newbys anyway
http://www.camarohomepage.com/ls3/index.htm
Old Oct 28, 2009 | 08:01 PM
red 454's Avatar
Originally Posted by 99blancoSS
Because of the price of the LS7 block the resleeved LS2 becomes a better option with being able to add a slightly longer sleeve and bigger bore. Add in the cracking issue under certain conditions with the LS7 block and the LS2 becomes more desirable.
i gather you are limited to 4.155 bore for fi with ls2 re sleeve and 4.185 for N/A reliability wise
is this the end of THE line for the block no room for future cleanup honing rebuilding ect ?
WOULD you be better of with as big a bore as possable and keep the stroke as short possable (still 454)for hi milage
would that keep the skirt in the bore with the wright piston rod combo
is the GM PERFORMANCE PARTS 454 crate WITH LSX HEADS as seen on seama show vido avalble yet dont seam to be much on there site price ect
GM PARTS say 4.25 bore on the new lsx extrem block
is this a newer version or is there only 2 lsx blocks high and std is the casting problem that thay hade a thing of the past now
Old Oct 29, 2009 | 08:10 AM
ringram's Avatar
Lots of detail there on the LS3 mate
http://www.corvettemuseum.com/specs/2006/LS7.shtml
Some here on the LS7.
Try and get a hold of the presentation last year at PRI for the ATEC from one of the GM LS7 team. Some good info on the extra work that goes into the LS7's
Old Oct 29, 2009 | 11:58 AM
cutlass_455's Avatar
Doesnt the LS9 head have a thicker deck that would allow it to stand up to FI (obviously) or nitrous?? To me, this solves one of the major drawback of the LS3/L92 head. Can the exhaust on the LS9 head be made to flow a bit better then the LS3/L92 one??
Old Oct 29, 2009 | 07:25 PM
red 454's Avatar
nice little lsx head vido from seama
link
http://video.google.com.au/videosear...d=0CBwQqwQwAA#
Old Oct 29, 2009 | 07:29 PM
NemeSS's Avatar
click link in my sig.
morris carries budget alum. ERL resleeved engines that will go from 427-500ci
Old Oct 29, 2009 | 10:25 PM
red 454's Avatar
what are your thoughts on thease ive never heard of them over here in the bush
http://www.totalseal.com/TechPage.aspx#trTSTechnology
Old Oct 30, 2009 | 11:31 AM
99blancoSS's Avatar
Good rings we were using them before Wiseco offered their GFX rings for everything.
Old Oct 30, 2009 | 02:19 PM
ERL Performance's Avatar
Total Seal has been around a long time and specialize in piston rings. We use them allot on our big boosted/ large displacement engine builds because they have every ring you could imagine and can put any combination together for you. They aren't cheap though but worth the money in some of these big builds of ours.
Just like 99blancoSS said the Wiseco GFX rings will do fine on most Street/Strip builds.
Old Oct 30, 2009 | 06:19 PM
red 454's Avatar
thanks for that info
do you use the gapless or just standard ones
cheers
Old Oct 31, 2009 | 11:32 AM
ringram's Avatar
One of the recent engine masters magazines had a review of rings, the gapless ones were about 10rwhp better than the usual gapped ones IIRC.
