Confused - which pilot bearing do I need?
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
You must have caught it very early in the process, because the input shaft will usually wear with the pilot bearing and not long after it makes those sounds, it'll mar the input shaft badly! What do the flywheel and pressure plate look like?
Thanks.
