lifters ticking. please help
Old Dec 2, 2009 | 08:10 PM
slowsilverc5's Avatar
Default lifters ticking. please help
i currently installed a iron block 6.0 in my 97 vette, the motor only has 6000 miles. I installed the pollutor cam kit with pi springs and stock length push rods from tick performance.The setup has ran good for about 3 or 4 weeks and only has about 100 miles on it since the swap, but the other day on the way home from work i heared the lifters ticking on the passenger side. I checked it out by taking off the valve cover and cranking the motor, while running i checked to see if the oil was squirting from the pushrods and i have no oil, to the head on the passenger side. Thanks for the space.
Old Dec 2, 2009 | 08:17 PM
cgslow77's Avatar
just had this problem on my 6.0.... pull the lifters if possible and check for debris / metal shavings cloging them. i had one cloged, cleanded it, and now doesnt make a sound
Old Dec 2, 2009 | 08:24 PM
ight i'll try that the motor has killer oil pressure and only 6000 miles from the factory so i figured i mit have to get some aftermarket lifters because of the cam.
Old Dec 2, 2009 | 08:56 PM
cgslow77's Avatar
what are the specs on the cam
