Few questions on 402
Old Dec 19, 2009 | 12:06 AM
kahunaking's Avatar
Default Few questions on 402
So I have an SLP ZL402 motor in my gto. I just picked up the car and I have no clue what is even in the thing. Its got AFR heads and seems to idle nearly stock. Anyone know what these motors were supposed to put out from the factory? It looks like a stock intake manifold as well. What cams are out for a motor this sized to be a bit more aggressive without sacrificing too much mileage/drivability.
Old Dec 19, 2009 | 06:55 AM
jmdgto's Avatar
get a sponsor to spec out a cam. no telling what your rwhp is without more info. do you have any bolt on's? take it to a dyno. it is probally around 460-480 rwhp. but who knows.
Old Dec 19, 2009 | 10:06 AM
kahunaking's Avatar
Its got LT's into Loudmouth exhaust. And a built A4. I was not asking about the rwhp but more of what slp claims this motor makes at the flywheel. Its going to a dyno eventually. But how bad is the stock ls1 intake manifold for this application?
Old Dec 19, 2009 | 11:01 AM
87silverbullet's Avatar
The ls1 intakes are garbage. At the minimum put on an ls6 intake but a FAST woul be better.
Old Dec 19, 2009 | 09:47 PM
WhiteRhino's Avatar
It should already be a ls6 intake. Since that's what the Gto's came with.
Old Dec 19, 2009 | 10:18 PM
PUNISHER TA's Avatar
It could also be an LS2 Intake...
A pic would be helpful.
LS2 based is the first thing that comes to mind when i hear 402 in a Goat...
Old Dec 20, 2009 | 11:30 PM
WhiteRhino's Avatar
Yeh, forgot about the year switch. Should be a ls6 if an 04. 05-06 were ls2 intakes.
Old Dec 26, 2009 | 02:34 PM
kahunaking's Avatar
Well I did some more research on it. Its got an LS6 manifold, AFR 225 heads with the 72cc chambers, Its an SLP 402. No clue on the cam but it idles like stock.
Old Dec 26, 2009 | 09:57 PM
LSGunZ28's Avatar
It does not have any cam specs?
weird..
But just because it idles like stock does not necessarily mean its not gonna make decent power...
on a small/mild cam 402 you will probably make AT MINIMUM, 450+rwhp with those heads w/ No problem at all..
Old Dec 26, 2009 | 10:59 PM
someday's Avatar
never heard of SLP using AFR heads... u said u just picked the car up, from who? SLP? if so, then ask them... if not, then ask who u got it from, for the paperwork of what was done... if they don't have any paperwork, then don't even believe it has a 402... the cam that SLP used was a 224/228, .591/.600, 113lsa...
Old Dec 27, 2009 | 12:28 AM
Tom@SpeedInc's Avatar
SLP did sell AFR heads, and used them in their long block packages, 05/06
I think more recently they switched to L92 heads
SLP mostly used 236/236 cam in their 402 engines.
Old Dec 28, 2009 | 12:49 AM
kahunaking's Avatar
How did it idle? The car pulls pretty strong but does not seem to pulll that much more than a stock ls2 gto. I dont know if it needs some tuning, more cam, intake manifold, or what.
Old Dec 28, 2009 | 08:17 AM
Steel Chicken's Avatar
Somethings fishy here. If its an ls2 based setup, its the drive by wire throttle body, which won't fit the smaller ls6 manifold style cable TB (78mm).
Also, if its a 402 cubic inch motor and not just some SLP "402hp package" with those heads it ought to pull pretty hard, even with a wussy cam.
Old Dec 28, 2009 | 11:27 AM
kahunaking's Avatar
Its cable driven. It is a 402 cubic inch motor. It has the ZL stamp on the back from SLP And the AFR Heads are the big bore heads. So it cannot be a 5.7 like what came stock in the car.
Old Dec 28, 2009 | 01:39 PM
someday's Avatar
ok, 1st, your car is a 2004?... is the block iron or aluminum? SLP used iron (LQ4)blocks on the early 402s then switched to LS2 aluminum blocks on the later models... they used the 225cc AFR heads then switched to L92 when they came out... the standard cam in the 402 was a big 250/246, then also a 236/236... they came out with a 224/228 later and also a 216/229 for the L92 head engines...
SLP
go there and click on engine packages and see how many choices/variations there are...
Old Dec 28, 2009 | 03:06 PM
kahunaking's Avatar
My car is an 04, Aluminum block, AFR 1630 head's (225cc, big bore, 72cc chamber). I have been on their site and the only thing that doesnt make sense is the lack of power and stock like idle.
Old Dec 29, 2009 | 01:59 PM
so take it somewhere that has a dyno and tuning software and log the runs. maybe theres something wrong with it.
Old Jan 4, 2010 | 09:30 PM
Steve1969LS1's Avatar
Yea, get it dynoed..
That engine should pull hard depending on the cam. My LS2 402 (massaged AFR 205 heads) makes about 570hp and 535tq on the engine dyno.. think the cam is 236/240 on a 112 LSA
A good dyno sesion will tell you if something is wrong in regards to output.
