how much can l92 rods handle?
Old Feb 24, 2010 | 05:04 PM
01 BERGER CAMARO SS's Avatar
Default how much can l92 rods handle?
i plann o build in a 370 shortblock with ported l92 heads and a tvs1900.. I want to make around 550 to 600 rwhp. I have a stock l92 crankshaft that i plann on using, i also have the rods, can i just use those with arp bolts or should i dish out for the forged rods?
Old Feb 24, 2010 | 05:36 PM
dimetweaker's Avatar
plenty of people get by with stock. but if you can afford it, might as well do it before the motor goes in. forged goodies are more foregiving than factory stuff...
Old Feb 25, 2010 | 11:33 AM
cam's Avatar
cam
I was going to build a boost motor and did quite a bit of research on this. The consensus on the info I found seemed to say that 550 rwhp was about the safe limit for stock LS1/LQ9 type builds. Seeing as L92 rods and bottom end are stronger I'd say your safe with those goals
BUT....
Once you add boost the temptation to crank it up and go for more becomes very tempting and if you can afford it why not forge it so your future power levels are much much easier and safer to obtain?
Old Feb 25, 2010 | 01:13 PM
hotrodscrap's Avatar
A couple guys on here had said 6800 a few months ago. I don't really KNOW first hand, but had read that on here.
-SS
