Help. Oil on bolt.
Old Mar 1, 2010 | 09:37 PM
cannman440's Avatar
Default Help. Oil on bolt.
I'm putting a superchager on my ls2 gto and as i was removing the slp udp I noticed the bolt had oil on the last 3/4" of threads is this ok or should i be worried? any info would be great.
Thanks
Old Mar 2, 2010 | 10:13 AM
cam's Avatar
cam
IIRC theres supposed to be a small frost plug in the crank snout thats sealed in with some silicone type stuff from the factory. Not sure why it would be missing... Has the engine ever been apart?
Old Mar 2, 2010 | 11:33 AM
vettenuts's Avatar
I don't think oil on that bolt is an issue. It is within the timing cover/oil region and I believe the SLP is made by Powerbond which has a keyway machined into the hub giving the oil a path to the bolt. Mine was well oiled when I last removed it as well. The oil is sealed by the underside of the bolt head (stock bolt).
Old Mar 2, 2010 | 12:50 PM
cannman440's Avatar
The cam cover has been off before but the motor has never been fully torn down. I put some aftermarket goodies on last year and now im installing a superchager and a different cam. Thats when i noticed the oil on the bolt.
