Head Gaskets
Old Mar 4, 2010 | 04:06 PM
sommmatt's Avatar
Default Head Gaskets
So I'm a bit of a cheap bastard, and was wondering about head gaskets.
I have a 5.3, and I need two new head gaskets as I pulled the heads off of my motor to change lifters etc.
Just wondering do I need specific 5.3 head gasket, or will ones from a 5.7, or 6.0 or anything work? I only ask because a friend of mine has an LS1 5.7 head gasket that he would give me for free.
Thanks!
Old Mar 4, 2010 | 04:18 PM
davidws6's Avatar
Default Gasket
The cylinder bore is bigger on a 5.7. With that said, you'd loose a little bit of compression. + you'd have to check the thinkness of the gasket.
