OIL PUMP, engine builders, SDPC, someone help?
Old Mar 7, 2010 | 02:39 PM
dimetweaker's Avatar
Default OIL PUMP, engine builders, SDPC, someone help?
I know there are many people who want to know this;
I have searched, and searched some more, and im still getting mixed answers and I cant find a part number so maybe someone else can find them or has them; We know now that the AFM/VVT oil pump is way high flow, and too much for a motor that does not have AFM/vvt any longer. I can not find a part number for this pump. The VVT motors, specifically a L92 from an escalade, have a different pump in it. It is for VVT but no AFM, but I am eliminating VVT. I had the motor apart to be built and had the VVT pump reinstall thinking I could use it sans VVT. I did not get the part # off this pump while it was out, and now the motor is all built again. I want to see if the part # for the NON AFM but with VVT oil pump corresponds with any other pumps to see if I can use it or if I need to pull the motor apart again to replace it. Can someone help please
Old Mar 9, 2010 | 05:40 PM
Ttt!!!
