Aftermarket Block
Old Mar 22, 2010 | 11:52 AM
ATVracr's Avatar
Dont think my 460 is going to run out of Cyl. head.
Old Mar 22, 2010 | 11:57 AM
Robin L's Avatar
LS1Tech Sponsor
Ahahaha, yeah I figured with that block and those heads you would post that up. And 460 for those parts is still conservitive compared to the capability of those components.
How many people wil step up to the Comp block and the Canted Valve heads.
Robin
Old Mar 22, 2010 | 12:01 PM
ATVracr's Avatar
Robin
I agree 460 with that block and heads seems conservitive.
We'll see how it works out. Hoping to have it in the next couple of weeks.
Old Mar 22, 2010 | 12:11 PM
racer7088's Avatar
Thumbs up
Even with small heads or the same the larger engines win every time in real heads up racing with all else equal.
For instance in NMRA HS or PSCA HS or NMCA Pro Stock etc. where you can only get more inches with stroke in a small block the larger engines still HAVE to carry more weight.
Without carrying the extra weight they would win every single race they are at which is why every single race series requires the larger stuff to carry extra weight to slow them down to the lever of the higher rpm small stuff with less power.
Even with inline heads like the SBF stuff the bigger stuff wins heads up racing with the same manifolds heads and carbs unless weight is added on top of them.
Every race series on the planet is like this even Formula 1 since bigger is always faster and quicker everything else equal.
There are diminishing returns in all out racing though as Robin said and for extreme power adders you need stronger pistons and cranks etc. so you have to put different priorities on parts than strictly NA of course.
On the street a 500 inch LS1 is MUCH nicer than a 400 incher and that's why Comp and everyone else is doing it. Drive one of these and it's all clearer. It's mush easier to make big power with a larger engine than a smaller one and even more so on the street with low rpm hydraulic roller stuff and these new better and bigger heads.
Old Mar 22, 2010 | 12:22 PM
ATVracr's Avatar
If we were doing a N/A motor we would have tried built it as close to 500" as possible.
That would be badass !
Old Mar 22, 2010 | 12:27 PM
racer7088's Avatar
Thumbs up
I know you guys and Robin need some strong *** pistons and cranks as well!
Old Mar 22, 2010 | 12:31 PM
Robin L's Avatar
LS1Tech Sponsor
OK now were are splitting hairs. On the street a big inch engine is a dream to drive. GMPP (thomspon) did a 454 a few years ago and stuffed it into an Impala SS. It was more fun than the ZO6 on the power tour.
If you want to spin it to 10,000 RPM a big inch LS (over 460 LOL) isn't the way to go. IMO
Why is Judson's N/A deal a small cube engine?
Once the heads become the limit then the extra cubes have a diminishing rate of return.
I can count on one hand how many people posess the type of heads required to make a 500 inch LS beat my little engine.
Robin
Old Mar 22, 2010 | 12:33 PM
Robin L's Avatar
LS1Tech Sponsor
LOL isn't that the truth....
Robin
Old Mar 22, 2010 | 12:40 PM
racer7088's Avatar
Thumbs up
Robin
I think Judson's was the biggest engine there at the shootout maybe? It is already at 3510 pounds and still ran 8.5Xs though by their rules. If the rules said he could run any engine size I have a weird feeling it would get somewhat even bigger but no one lets you do that since of course the wee ones would get slammed just like in any racing.
Also the cranks really need to be CCW style at higher rpm when they are big strokes or the move too much at those power levels so the crank costs double or triple but at 7500 and down they seem to last forever. Of course all engines turning 9k+ dont last too long as far as that goes unless they are $85+K Cup stuff.
Old Mar 22, 2010 | 08:04 PM
fuel's Avatar
hay roben what kind of parts list do you have...i learning the ls stuff as we speak.....i have a 383 and allwas wised i had a 396.......i dont want to to build somthing smaller and wished it was a 500ci
Old Mar 24, 2010 | 09:14 PM
Blksilvr's Avatar
Anyone used the Dart or WarHawk block?
Old Mar 26, 2010 | 12:22 PM
  #32
Quick Carl's Avatar
From the LSX shootout All Motor rules;
WEIGHTS
Base CID Base weight
370 3150
420 3300
440 3375
470 3450
8.5 lbs/cu in penalty applies for cubic inches over base weight break limit. (Maximum cubic inch still applies.)
Old Mar 26, 2010 | 02:13 PM
  #33
AES Racing's Avatar
I had noticed Shawn posted this on bullet, looks promising
http://www.yellowbullet.com/forum/sh...d.php?t=226130
Old Mar 26, 2010 | 07:16 PM
  #34
Shawn @ VA Speed's Avatar
That sure is a good looking block
Old Mar 27, 2010 | 01:25 PM
  #35
BigRich954RR's Avatar
I'm using the Warhawk block what u asking or want to know ? I have a few buddies running them too?
Old Mar 27, 2010 | 08:26 PM
  #36
fuel's Avatar
on a tall deck lsx block, does that effect the header height
