Zero oil pressure pump failure?
Old Mar 22, 2010 | 10:34 AM
12leavu's Avatar
Default Zero oil pressure pump failure?
I lost oil pressure this weekend , started getting valve train noise, started car Again and it had pressure, drove car one mile parked it, no noise and it had oil pressure. Restarted car again zero oil pressure and valvetrain noise again. This Is 402 ls2 been in car for 8000 miles. I changed the filter wondering if it was clogged and hooked an external oil pressure gauge to it, crank for just a second still has no oil pressure, could the pump have failed, the car was idleing when it lost pressure. I didn't hear anything break or pop
Old Mar 23, 2010 | 10:31 PM
12leavu's Avatar
The pressure bypass valve was stuck open inside the pump, maybe this will help someone in the future.
Old Mar 30, 2010 | 09:18 AM
A_VAS's Avatar
which oil pump you running here? Melling or a stocker..something else?
thanks
Old Apr 26, 2010 | 05:53 PM
12leavu's Avatar
thanks
Ported ls6 from tsp I beleive
