break in process...
Properly setup with the right component parts the engine is broken in in one full heat cycle at moderate RPM. 30 years ago you might want more breakin time but now with diamond honing and alloy rings it doesn't take anywhere near as long.
Just my $.02
If you use the joe gibbs BR you need to used the total sump capacity to get the desired effect. Keep in mind this oil is high in zddp and if you use half you are getting half of the additives. Using only 1 quart wouldnt be worth it and you would see zero benefit from doing so.
http://jillandkate.files.wordpress.c...asy-button.jpg
delo 400 CI-4 is the off the shelf oil with the highest zddp and phosphorous content, but it has been replaced with CJ-4, which has about 300 ppm less zddp and is still fine for mild spring pressure and street cams.
again, this does not apply to the simple question the OP asked. run what the mfg intended, mobil 1 with a viscocity based on your engine clearances, and go.
