LSX nitrous piston
Old Apr 21, 2010 | 03:28 PM
AES Racing's Avatar
Default LSX nitrous piston
Heres a Diamond piston we custom spec'd for plenty of nitrous. LSX tall deck block.
Minus any coating or anodizing its tough as you can make them.
Attached Thumbnails LSX nitrous piston-dpcustom.jpg   LSX nitrous piston-dpcustom1.jpg
Old Apr 21, 2010 | 04:01 PM
JPH's Avatar
JPH
Looks good. What's the ring package sizing?
Old Apr 21, 2010 | 04:27 PM
03supercobra's Avatar
Very nice piece! Looks like plenty of support around the wristpin area!
Old Apr 21, 2010 | 04:28 PM
AES Racing's Avatar
For this application we normally use a .043" 1st/2nd ring
this will be driven on the street, went with 1.5,1.5,3.0
Fraser
Old Apr 21, 2010 | 04:57 PM
JPH's Avatar
JPH
Fraser
Ah, I see. Cool. Keep up the good work.
Old Apr 21, 2010 | 05:23 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That extra deck height sure helps.
Old Apr 21, 2010 | 06:22 PM
AES Racing's Avatar
Originally Posted by fafnir
what are the piston weights?
also, what stroke/rod length is the piston spec-ed for?
thanks for the time
_
498 grams piston / 122 grams pin
4.250" stroke
6.300" rod
1.250" CH
GRP aluminum rods.
Glad I was able to see the pistons before ordering rods,
changed dimension on the small end of the rod slightly.
thanks
Old Apr 21, 2010 | 08:40 PM
ATVracr's Avatar
Very Nice !!
Any pics of the tops with valve reliefs cut in them?
Old Apr 21, 2010 | 08:52 PM
AES Racing's Avatar
Originally Posted by ATVracr
Very Nice !!
Its just regular flat top with valve reliefs, I didn't like the pics of the tops of the pistons for, i'll get a light box one of these days for pictures.
Old May 10, 2010 | 04:51 PM
AES Racing's Avatar
Rods came in and pistons are back from coating
GRP 2000 series rods, 7/16" ARP 2000 rod bolts
rods are 544 grams.
Old May 11, 2010 | 08:27 AM
ATVracr's Avatar
Nice.
Are the valves small? or do they not sink into the piston lot?
All of our flat top pistons always have the valve relief into the edge of the piston which sucks for nitrous as I'm sure you know.
Old May 12, 2010 | 12:51 AM
AES Racing's Avatar
Nice.
2.125"/1.60" valves
I'd rather have to cut the reliefs then have too much valve relief for no apparent reason, that mentality doesn't work for everyones budget. Theirs plenty of material in those pistons, we should be fine though on clearance, I'll let you know how it goes.
Old May 12, 2010 | 03:19 AM
OWN3D BY MY PROF!
Is there an oiling hole on the big end of the rod cap?
Old Jun 27, 2010 | 06:05 PM
Firehawk441's Avatar
How well do those rods fit with that stroke?
Old Jun 28, 2010 | 02:05 AM
AES Racing's Avatar
I think you're looking at the dowel pin?
In terms of? The pistons clear the counterweights.
Old Jun 28, 2010 | 03:37 AM
brandoz28's Avatar
gotta love a street driven motor with aluminum rods!
that's going to be a screamer
