Bore/Stroke Idea
Go for it!
You can use a 1.220" CH piston, lot thicker then whats used with a 4.000" stroke. We've seen 408 boost pistons come in with lifted top ring land tweeked and peeled over, cracked in the valve pocket to the top ring groove, in some cases people may have not noticed the drop in compression.
I'd advocate the use of 3.825 crankshaft and I think its better combination for boosted engine with the right piston vs. the usual 1.110" stuff.
Fraser
a shop car we had at Speed used a Callies Magnum 3.75" crankshaft, 383ci LQ9 with twin 70mm turbochargers.
Keith Black just came out with the 3.905 pistons for that 3.825 crank. Uses a 6.125 rod as well. Im looking at helping a friend build an engine with that one. Call it a "half stroker" lol.
At 366 ci with some nice CH numbers it would be a killer idea really.
