thickest pushrod in a LS3 block/head?
Old May 12, 2010 | 09:17 AM
JimMueller's Avatar
Default thickest pushrod in a LS3 block/head?
How thick of a pushrod can I use with these components without massaging the block or head? 3/8? 7/16? Can it be straight or does it need to be tapered in a specific manner? Head will be milled about .030 if that matters.
Old May 12, 2010 | 09:59 AM
WKMCD's Avatar
I've run Manton 11/32's without opening anything up. I'm running 3/8's now in worked heads.
Old May 29, 2010 | 11:01 PM
offaxis's Avatar
Ive heard the 3/8 fit with stock heads. I tried them with my morel lifters and they did not fit . I am not sure if the stock lifters would have made a difference. Hope that helps
Old May 30, 2010 | 11:04 AM
LS1 BU's Avatar
There is more clearance for bigger pushrods on l92/ls3 heads than other ls gm heads. I only had to open the holes up slightly to fit 3/8 pushrods.
Old May 30, 2010 | 11:45 AM
JimMueller's Avatar
I've used 3/8's in the last two motor builds (both using 5.3l heads) and there's some very minor 'polishing' on certain sections of certain pushrods upon removal. Not sure if that's acceptable? I don't recall if I had that on the OEM / Comp Cam 5/16 pushrods in the past.
